AutoCAD Structural Detailing General DIscussion
Active Member
job_delacruz
Message 1 of 3 (533 Views)
Connection Shearplate - Beam_column web at an Angle
533 Views, 2 Replies
07-23-2012 08:59 PM
The "Connection Shearplate - Beam_column web"  does not work when the beam is connecting to the column in an angle postion. What is the work around? Or is there any other connection type that can be use with this situation?
Please see attach picture below for reference:
Job
Product Support
Jakub.Brozonowicz
Message 2 of 3 (520 Views)
Re: Connection Shearplate - Beam_column web at an Angle
07-24-2012 06:21 AM in reply to: job_delacruz
It is possible only for very small angle positions ~1 degree.
Only manual adjusting is possible for bigger angles.
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Jakub Brożonowicz
Active Member
job_delacruz
Message 3 of 3 (507 Views)
07-25-2012 06:13 PM in reply to: Jakub.Brozonowicz
Ok, noted. Can you show me an example of the manual adjustment if the column rotate more than 1 degrees.
Job
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
