AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Connection Shearplate - Beam_column web at an Angle
2 REPLIES 2
job_delacruz
932 Views, 2 Replies
The "Connection Shearplate - Beam_column web"  does not work when the beam is connecting to the column in an angle postion. What is the work around? Or is there any other connection type that can be use with this situation?
Please see attach picture below for reference:
Job
2 REPLIES 2
It is possible only for very small angle positions ~1 degree.
Only manual adjusting is possible for bigger angles.
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Jakub Brożonowicz
Global Product Support
Ok, noted. Can you show me an example of the manual adjustment if the column rotate more than 1 degrees.
Job
”Boost
”Tips
