AutoCAD Structural Detailing General DIscussion
Active Member
0 Kudos
Post 1 of 3
Connection Shearplate - Beam_column web at an Angle
552 Views, 2 Replies
07-23-2012 08:59 PM
The "Connection Shearplate - Beam_column web"  does not work when the beam is connecting to the column in an angle postion. What is the work around? Or is there any other connection type that can be use with this situation?
Please see attach picture below for reference:
Job
It is possible only for very small angle positions ~1 degree.
Only manual adjusting is possible for bigger angles.
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Ok, noted. Can you show me an example of the manual adjustment if the column rotate more than 1 degrees.
Job
Product Support
32 Kudos
Post 2 of 3
Re: Connection Shearplate - Beam_column web at an Angle
07-24-2012 06:21 AM in reply to: job_delacruz
Jakub Brożonowicz
Active Member
0 Kudos
Post 3 of 3
07-25-2012 06:13 PM in reply to: Jakub.Brozonowicz
Job
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
