AutoCAD Structural Detailing General DIscussion
benniebadenhorst
Message 1 of 3 (343 Views)
Connection ignore weld on one rib
343 Views, 2 Replies
09-27-2012 01:45 AM
Hi
Im using the macro ' End plate- Beam/beam with rib. Every time the one rib does not get welded to the main beam. It isnt always the same rib that gets neglected, sometimes the one on the connection side, other times the one on the back side.
On the attached picture it is the rib on the connection side.
Any idea why this is happening?
Valued Contributor
lucis29
Message 2 of 3 (305 Views)
Re: Connection ignore weld on one rib
10-01-2012 11:30 PM in reply to: benniebadenhorst
Maybe is just a view glitch. Try Regen very close to the Connection.
Try to create a group from the Connection Elements, add a Drawing and see if it can recognize the weld. If not, that's a problem.
benniebadenhorst
Message 3 of 3 (302 Views)
10-01-2012 11:57 PM in reply to: lucis29
Hi
It is not just a view glitch. I detetmined that he one rib actually penetrate the main beam, and that is why the weld is not created. It is still odd that the automatic connection does not fit the rib to the beam correctly.
Autodesk Alert | We are currently working on restoring Previous Version License request access in the Autodesk Subscription Center. If you are a subscription customer and would like to request a Previous Version License, please use this link as a temporary workaround. We apologize for the inconvenience and thank you for your patience.
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
