AutoCAD Structural Detailing General DIscussion
Valued Contributor
johnshort
Message 1 of 5 (634 Views)
Connect a Rib to a Pipe
634 Views, 4 Replies
01-20-2013 04:44 PM
I have a pipe that is part of a supporting structure, acting as a column. What I need is to weld a rib/plate to the side of the pipe so I can add back-to-back angle bracing.
Is this possible? I tried various ways, but with no luck. I tried to add a plate, but can't seem to figure out how to get it to rotate to the right orientation.
Product Support
Jakub.Brozonowicz
Message 2 of 5 (614 Views)
Re: Connect a Rib to a Pipe
01-21-2013 07:33 AM in reply to: johnshort
You mean sample like attached or different thing?
Please share your file.
Jakub Brożonowicz
Valued Contributor
johnshort
Message 3 of 5 (610 Views)
01-21-2013 08:31 AM in reply to: johnshort
Almost exact. the problem I'm having is that when I add the plate, it will only go in parallel to the end of the pipe.
I must be missing sometihng simple. i should be able to rotate it so it's perpendicular, but it won't work.
How did you do it?
Product Support
Jakub.Brozonowicz
Message 4 of 5 (595 Views)
01-22-2013 03:45 AM in reply to: johnshort
I did it by macro (see here).
What was you path of doing it?
Jakub Brożonowicz
Furneaux
Message 5 of 5 (425 Views)
11-09-2013 10:32 PM in reply to: Jakub.Brozonowicz
same question, please see http://forums.autodesk.com/t5/AutoCAD-Structural-Detailing/Rotate-connection/m-p/4606617
Autodesk Inventor Professional 2013 Service Pack 1.1 Update 1
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
