AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Connect a Rib to a Pipe
4 REPLIES 4
johnshort
978 Views, 4 Replies
I have a pipe that is part of a supporting structure, acting as a column. What I need is to weld a rib/plate to the side of the pipe so I can add back-to-back angle bracing.
Is this possible? I tried various ways, but with no luck. I tried to add a plate, but can't seem to figure out how to get it to rotate to the right orientation.
4 REPLIES 4
You mean sample like attached or different thing?
Please share your file.
Jakub Brożonowicz
Global Product Support
johnshort
in reply to: johnshort
Almost exact. the problem I'm having is that when I add the plate, it will only go in parallel to the end of the pipe.
I must be missing sometihng simple. i should be able to rotate it so it's perpendicular, but it won't work.
How did you do it?
I did it by macro (see here).
What was you path of doing it?
Jakub Brożonowicz
same question, please see http://forums.autodesk.com/t5/AutoCAD-Structural-Detailing/Rotate-connection/m-p/4606617
Autodesk Inventor Professional 2013 Service Pack 1.1 Update 1
”Boost
”Tips
