AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Clip Angle Connection - Clipping Member
10 REPLIES 10
Message 1 of 11
1161 Views, 10 Replies
I am using a Clip Angle Connection with at an intersection of 2 Channels. When I accept the Connection it automatically clips the end of one of the Channels.
Is there a property I am missing when filingl in the information on the Connection?
10 REPLIES 10
Message 2 of 11
Jakub.Brozonowicz
Which case it is that you asked about? (see attached)
Jakub Brożonowicz
Global Product Support
Message 3 of 11
Unfortunately I am not able to open the file you attached due to having an earlier version of ASD. I have attached a file showing the problem.
Then Connection is clipping the member only along the bolted side of the Angle when it should be extending to the face of the intersecting member.
Thank You for your Reply.
Message 4 of 11
Jakub.Brozonowicz
You mean this here.
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Jakub Brożonowicz
Message 5 of 11
in reply to: Jakub.Brozonowicz
Sorry I must not be explaning this correctly. This video here is what I mean.
2013-02-14_0827
Message 6 of 11
Jakub.Brozonowicz
You make a mistake choosing secondary beam as main one (?)
Jakub Brożonowicz
Message 7 of 11
I need the connection to look like the pdf i attatched. By selecting the other beam it puts the Angles on the wrong side. Am i using the wrong Connection all together?
Message 8 of 11
Jakub.Brozonowicz
Please try Clip-angle - Beams/Beam web-double sided.
Jakub Brożonowicz
Message 9 of 11
Ofcourse, something so simple,
 Thank You so much
Message 10 of 11
Jakub.Brozonowicz
Cool.
Accept as solution?
Jakub Brożonowicz
Message 11 of 11
Yes, I had previously missed the Check Box that lets you select the Left and or Right sides in the Clip Angle Double Side Connection.
Thanks Again
”Boost
”Tips
