AutoCAD Structural Detailing General DIscussion
Active Member
JBrigadier
Message 1 of 11 (556 Views)
Clip Angle Connection - Clipping Member
556 Views, 10 Replies
02-13-2013 11:29 AM
I am using a Clip Angle Connection with at an intersection of 2 Channels. When I accept the Connection it automatically clips the end of one of the Channels.
Is there a property I am missing when filingl in the information on the Connection?
Please try Clip-angle - Beams/Beam web-double sided.
Product Support
Jakub.Brozonowicz
Message 2 of 11 (541 Views)
Re: Clip Angle Connection - Clipping Member
02-14-2013 03:43 AM in reply to: JBrigadier
Which case it is that you asked about? (see attached)
Jakub Brożonowicz
Active Member
JBrigadier
Message 3 of 11 (533 Views)
02-14-2013 04:32 AM in reply to: JBrigadier
Unfortunately I am not able to open the file you attached due to having an earlier version of ASD. I have attached a file showing the problem.
Then Connection is clipping the member only along the bolted side of the Angle when it should be extending to the face of the intersecting member.
Thank You for your Reply.
Product Support
Jakub.Brozonowicz
Message 4 of 11 (516 Views)
02-14-2013 05:13 AM in reply to: JBrigadier
You mean this here.
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Jakub Brożonowicz
Active Member
JBrigadier
Message 5 of 11 (513 Views)
02-14-2013 05:33 AM in reply to: Jakub.Brozonowicz
Sorry I must not be explaning this correctly. This video here is what I mean.
2013-02-14_0827
Product Support
Jakub.Brozonowicz
Message 6 of 11 (503 Views)
02-14-2013 05:43 AM in reply to: JBrigadier
You make a mistake choosing secondary beam as main one (?)
Jakub Brożonowicz
Active Member
JBrigadier
Message 7 of 11 (499 Views)
02-14-2013 05:50 AM in reply to: Jakub.Brozonowicz
I need the connection to look like the pdf i attatched. By selecting the other beam it puts the Angles on the wrong side. Am i using the wrong Connection all together?
Product Support
Jakub.Brozonowicz
Message 8 of 11 (482 Views)
02-14-2013 06:13 AM in reply to: JBrigadier
Jakub Brożonowicz
Active Member
JBrigadier
Message 9 of 11 (479 Views)
02-14-2013 06:22 AM in reply to: Jakub.Brozonowicz
Ofcourse, something so simple,
 Thank You so much
Product Support
Jakub.Brozonowicz
Message 10 of 11 (473 Views)
02-14-2013 07:14 AM in reply to: JBrigadier
Cool.
Accept as solution?
Jakub Brożonowicz
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
