Good day
Thank you for your reply. I need the ASD automatically to generate the bar splice and locate it in predefined zones / ranges ( i.e. compression zones ) . Even if I use the " 2 arrows " method, still I need to relocate the splice, because it has been generated depend on / based on the available total length of the bars used. Also the mirror option does not work, totally we can not edit the splice location to accommodate it in the required zones.
Any way, Autodesk they will issue ASD2010 (it will come at the end of this month) which will include this option ( change / edit the splice location )
