AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Changing to Metric (2013)
1 REPLY 1
sakroeke
1535 Views, 1 Reply
This seemingly should have an easy answer, but I'm totally lost. I would like to draw some simple cross sections in metric units. I understand how to toggle the annotate dimensions, but I don't understand how to change the toolbar things into metric. I have tried changing the 'Drawing Units' to millimeters, but this does not affect the toolbar items. For example, when I want to use the 'Reinforcement - cross-section' button on the toolbar, even if I've changed the Drawing Units to metric, it still asks for input in inches. I found a similar problem in the Inventor community, and the solution was to open the Metric template. I tried opening the 'Civil Metric Sheet Set' in the templates folder, but still the toolbar items ask for inches.
Any help on this issue is greatly appreciated!
Cheers
1 REPLY 1
Jianna
in reply to: sakroeke
Go to the ASD model tab, then click on Project Preferences button 2nd from the righthand side. Then there will be a units category in that dialog box.
”Boost
”Tips
