Hi, i am testing ADSD2009, When I use the predefined workframe such a box, I put the profiles without problem, then If I modify the Box workframe, I can't finde the update command, or with this predefined workframes I cannot update any changes to the profiles?
In another words, the wire frame that we can insert, and using for insert profiles is parametric?
Technical Specialist
Nexsys de Colombia
