AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
707 Views, 6 Replies
Chain Style
when customizing my ASD, i created my own dimension style and linked it with Profile - Standard deimensioning style.
everything works as i want except the chain dimension produced for bevele and cuts at Absolute - chain dimension format.
the text height of the chain is very big compared with all the other dimensions, causing a mesh.
Does anybody knows how can i customize this dimension to produce correct drawings and not correcting them one by one manually.
Thanks in advance
6 REPLIES 6
Jakub.Brozonowicz
Please better show how it looks.
None of expected effect after attempt like you described.
Jakub Brożonowicz
Global Product Support
i attch snapshots with the problem and the settings i use.
if needed ican upload a lot of cases
Jakub.Brozonowicz
OK
Lets start with this one.
Has this dim style same sizes of text like the major one?
Any chance to upload the dwg with the sample?
Jakub Brożonowicz
in reply to: Jakub.Brozonowicz
i saved printout as dwg if that would help.
Also i attach some screenshots to show you that the dim style is the same. i know that at the screenshot from absolute bevel dim it shows the symbol of annotative and in the overal dimension no but i only have one text style named ' Profile Text 10'.
By the way, i can not find any option to change the dim style of the absolute  bevel and cut dimensions.
Jakub.Brozonowicz
Is there any chance to share the model not only the printout?
Jakub Brożonowicz
the file is very big so i erase everything i could but still is 9.7MB. any ideas?
”Boost
”Tips
