AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
cap plate connection
11 REPLIES 11
Message 1 of 12
jorgeluisg12
3392 Views, 11 Replies
Anybody knows how to make the connection between steel column to underside of flange beam.
In other programs it´s typical cap plate but here ASD don´t have this option.
Profiles are welded plates (double T).
11 REPLIES 11
Message 2 of 12
Tony_Gibbs
in reply to: jorgeluisg12
Easy Done
Use macro End plate:Column to beam flange. I tried it with a SHS column and it wouldn't work so I changed the column to a UB and then it works good. After you get every thing correct explode the macro and change the column back to it's original
Hope this works for you
Message 3 of 12
jorgeluisg12
in reply to: Tony_Gibbs
Tony,
 I´ve tried but ASD don´t recognizes the welded plate beam as a valid object for this connection
Message 4 of 12
Tony_Gibbs
hi
Send me your drawing with the example and I'll give it a go
Regards
Tony
Message 5 of 12
jorgeluisg12
Hi Tony
This is a tyipical- easy-standard end plate connection (fixed stiffened)
Message 6 of 12
jorgeluisg12
Tony
If you can help me, please explain based on this attached work
Message 7 of 12
Tony_Gibbs
Hi Jorge
I've tried to open this file but keep getting a fatal error
Can you maybe resend but stip it out to only be the members required
Regards
Tony
Message 8 of 12
jorgeluisg12
Tony, Sorry  for the delay, I´m working too much.
This drawing only contains a pair of pieces.
Anyway, I´ll not continue using/trying to learn ASD for welded plates structures, I think if I need two o more steps to obtain
a similar structure which I will obtain just in one step in other programs is too much.
I use ASD for hot rolled profiles so I hope you can help me in the future.
Thanks for your time.
Message 9 of 12
O.Maille
Hope there will be some way of creating additional macros, the program is practically unusable if you can't use SHS/CHS/RHS, can't create cap plate connections, I've only started using it but so far to bad!
Message 10 of 12
jorgeluisg12
in reply to: O.Maille
 I think each company has his strenght, ASD isn't for Autodesk.
In a Latinoamerican forum someone said me a few months ago that this is a good program but have a long road ahead, we can't obtain all we need as another program.
Today ASD can't works with all structures, just with a limited range as you said.
I'll continue looking for another program, there are many to see.
Message 11 of 12
Rich.O.3d
A year later and im trying to do this type of connection...keep getting the 'Selected profiles does not meet criteria of this type of connection' error
Has anyone had issues with this still
ASD-2012
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
Message 12 of 12
Yes. Use the "inverted" Endplate - Beam to column flange connection.
”Boost
”Tips
