Command: TOOL_IMPORT_RM
_regenall Regenerating model.
Command: _regenall Regenerating model.
Command: No active document
This is what i get
Which version of ASD?
Please join the rtd file to your request to check this import?
Thanks.
i have ASD 2012 with a student license and Robot also with a student License .
I've attached the .rtd file here :
The frame of your structure can be only imported on ASD-steel if you let your file open in RSA.
But i need to extract the reinforcement plans from this building . Is that possible?
If your RC elements are calculated on RSA, you could import your reinforcement drawings on ASD- Reinforcement, you can also import your Reinforcement area from Robot if your panels are calculated before.
Im not that of an advanced user in RSA.How can i import / export the drawings ? I only know how to do the statical calculus.
I did that sizing calculu in mathcad and just added the sizes of the elements while designing in robot
Please go to this website: http://www.robotoffice.com/asd/
And see the movie Integration with other Autodesk Programs (RC), you will see how to import drawinf from RSA to ASD- reinforcement.
