AutoCAD Structural Detailing General DIscussion
New Member
0 Kudos
Post 1 of 3
Bug: Visibility States in Block Editor
494 Views, 2 Replies
08-17-2012 09:42 AM
BUG FOUND: AUTOCAD STRUCTURAL DETAILING 2013 - Visibility States in Block Editor
I found a bug in AutoCAD Structural Detailing 2013 when editing a dynamic block in block editor involving the visibility states. After opening a previously created block (from an AutoCAD 2010 format file) with block editor I select one of the alternate visibility states (previously defined with the visibility states parameter). After selecting the visibily state, the block editor immediately jumps back to the visibility state at the top of the list. I tried this several times and on different computers with different files and every time I encountered the same problem. I then re-opened the same file with AutoCAD Structural Detailing 2012 and did not have the same problem as I did with the 2013 version.
--PLEASE ADVISE--
Member
2 Kudos
Post 2 of 3
Re: Bug: Visibility States in Block Editor
08-20-2012 04:28 AM in reply to: alyssacornett
i have the same problem in AutoCAD Structural Detailing 2013
Product Support
32 Kudos
Post 3 of 3
08-27-2012 06:21 AM in reply to: jimmyvb
Unfortunately this is general problem of combos in ASD 2013.
Jakub Brożonowicz
Post to the Community
New Post
Need installation help?
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
