BUG FOUND: AUTOCAD STRUCTURAL DETAILING 2013 - Visibility States in Block Editor
I found a bug in AutoCAD Structural Detailing 2013 when editing a dynamic block in block editor involving the visibility states. After opening a previously created block (from an AutoCAD 2010 format file) with block editor I select one of the alternate visibility states (previously defined with the visibility states parameter). After selecting the visibily state, the block editor immediately jumps back to the visibility state at the top of the list. I tried this several times and on different computers with different files and every time I encountered the same problem. I then re-opened the same file with AutoCAD Structural Detailing 2012 and did not have the same problem as I did with the 2013 version.
--PLEASE ADVISE--
Unfortunately this is general problem of combos in ASD 2013.
