AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Bug in ASD 2013
3 REPLIES 3
ZHUKOV_ING
529 Views, 3 Replies
Bug in ASD 2013
I am reporting one bug that i notice after releasing the sowtware: When i select some asd object and try to change the color then color meny is disapearing and color of the elemet remains unchanged see video:  http://www.screencast.com/t/MrjMVxijap
One more thing that i notice yesterday, when i start wit generating the drawings then saving the model was very very long.
3 REPLIES 3
in reply to: ZHUKOV_ING
It's not only the color , the same happens if you try changing linetype , or lineweight . But if you change it and then draw the element , you can use matchprop to change the others you want to change . It's a workaround , but the bug is annoying and needs fixing .
Same here. What about ACAD vanilla? Same bug?
Pawel.Pulak
These eeffects are  not observed when using "classic" workspaces:
It is also not observed on "vanilla" AutoCAD started using "AutoCAD" profile instead of "AutoCAD Structural Detailing" profile.
It is forwarded to development team to be investigated.
Pawel Pulak
Technical Account Specialist
”Boost
”Tips
