I am reporting one bug that i notice after releasing the sowtware: When i select some asd object and try to change the color then color meny is disapearing and color of the elemet remains unchanged see video: http://www.screencast.com/t/MrjMVxijap
One more thing that i notice yesterday, when i start wit generating the drawings then saving the model was very very long.
It's not only the color , the same happens if you try changing linetype , or lineweight . But if you change it and then draw the element , you can use matchprop to change the others you want to change . It's a workaround , but the bug is annoying and needs fixing .
These eeffects are not observed when using "classic" workspaces:
It is also not observed on "vanilla" AutoCAD started using "AutoCAD" profile instead of "AutoCAD Structural Detailing" profile.
It is forwarded to development team to be investigated.
