AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Breaklines on columns and beams
2 REPLIES 2
princecompany
558 Views, 2 Replies
When creating automatic drawings in ASD, how do I prevent breaklines from being used on columns and beams.
2 REPLIES 2
I think there is a command in ASD steel documentation module / ribbon panel for this.
You first need to activate the drawing and select the view. then use the Remove BREAK LINE command.
You can activate the drawing by selecting it in Object Inspectior Right+Click and select activate.
see if it works for you in your case.
NEIL
Avaerni
in reply to: princecompany
In the 2nd tab in the adjust styles command.
There is a tick box option called "Parts Shortening" If you turn it off the part will revert automatically to it's full shape.
As was mentioned you do have to be in the active view in the editions layout.
”Boost
”Tips
