AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Bolts get removed
2 REPLIES 2
boydc
404 Views, 2 Replies
Bolts get removed
When ever I go and do a batch plot or plot from the sheet set manager my bolts diappar from my objector inpector.  The only way I can get them back is if I click on the bolts in model space and then modify the connection.
Any ideas of why this is happening and is there an easier way to repopulate the nuts and bolts.
2 REPLIES 2
in reply to: boydc
When I find that things are dissapearing from the Object Inspector, I always switch tabs. For example, if something isn't showing up in my Model tab, I'll switch to the Parts Edition tab then back to the Model tab. This generally works for me, but I've found that with this program there are a lot of... quirks, and you just have to learn to work around them 😕
boydc
Wish it was that easy.  At this point I need to save the file plot and then if it eliminates reopen the file.
”Boost
”Tips
