When I create a bolt list of a structure, it says for example that I will only need 228 off M20 Bolts.
I know that this quantity is incorrect since i did a bolt list earlier the week (before adding additional beams) and then I needed 1268 off M20 Bolts.
Is there anything I should be aware off which can cause this problem. I made sure to select the entire structure.
ASD Bolt mistake
http://forums.autodesk.com/t5/AutoCAD-Structural-Detailing/Model-Drawing/td-p/3741748
This structure ASD bolt list <<< 500..600 pieces, when edit macro and change any ASD bolt break
When I use the model size macro it shows that I have 1743 Bolts, but the bolt list only shows 574 Bolts total. I dont understand how to fix it.
