AutoCAD Structural Detailing General DIscussion
StefanoPasquini6790
Message 1 of 6 (463 Views)
Bolt elimination without bolt elimination
463 Views, 5 Replies
06-07-2012 03:40 AM
Hello everyone, there is a way to delete all the bolts of a structure, without eliminating the holes?
PasProStudio
Structural + Detailing engineers
The request to enable multiselection in "Remove bolts" command was added to the wish list to be considered in future versions of ASD.
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Distinguished Contributor
CristianLANCULESCU1367
Message 2 of 6 (453 Views)
Re: Bolt elimination without bolt elimination
06-08-2012 05:31 AM in reply to: StefanoPasquini6790
You can hide the bolts...
Right click-> Isolate->Hide objects
Product Support
pp2008
Message 3 of 6 (441 Views)
06-12-2012 02:52 AM in reply to: CristianLANCULESCU1367
Additional information to already provided by Cristian:
1/ Multiselection to select many or all bolts prior to "Hide objects" command can be made in Object Inspector configured to display only bolts:
2/ it is also possible to switch off the display of all bolts in Preferences:
3/ it is possible to delete bolts without deleting holes using the dedicated command "Remove bolts" - but it cannot be used for multiselection so it is necessary to remove them one by one:
4/ if your request is related only to the display of bolts on the drawings then it is possible to adjust the drawing style to do not display them
Pawel Pulak
StefanoPasquini6790
Message 4 of 6 (436 Views)
06-12-2012 03:29 AM in reply to: pp2008
Your suggestions are not usable. I need to "remove" the bolts and not to hide it! I tried to create a group of bolts and explode it....but nothing....
I was forced to individually delete every single bolt (~2000) in my model. You could implement the ability to set whether to link the bolts with the holes, giving the opportunity to delete them without deleting the holes!
Regards
PasProStudio
Product Support
pp2008
Message 5 of 6 (432 Views)
06-12-2012 05:54 AM in reply to: StefanoPasquini6790
Pawel Pulak
zcsillag
Message 6 of 6 (284 Views)
07-09-2013 10:42 AM in reply to: pp2008
Thx Pawel Pulak !
But my quistion is in which version ... 2050 ?
Regards
Csillag Z.
Regards
Csillag Zoltán
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
