AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Message 1 of 1
JohnHolder
524 Views, 0 Replies
Bent Plate
Attempting to bend a plate once again.
a plate, 109.473" wide by 57.5" tall ( standing vertically ) 3/8" width.
bent around a 151-1/16" Arc.
basically there are 9 plates around at 25.18" diameter circle.
All bolted together.
then a bent profile - angle iron around the outsides of both the top and bottom.
top angle is the edging of the tank, and to bottom angle is bolted to the tank foundation ( concrete )
it just does not want to bend.
any ideas?  I figured this should have been made much easier than it was a couple releases ago, but no.  still a nightmare.
John.
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
0 REPLIES 0
”Boost
”Tips
