AutoCAD Structural Detailing General DIscussion
detailer_wsa
Message 1 of 4 (940 Views)
Bending A Plate
940 Views, 3 Replies
04-10-2012 02:58 PM
Hello every one I need help on bending a plate  I keep on getting the same message eventhough I change the ucs view
Here is how I do it :
Command: '_-view Enter an option
[?/Delete/Orthographic/Restore/Save/sEttings/Window]: _right Regenerating model.
Command: 3do
3DORBIT Press ESC or ENTER to exit, or right-click to display shortcut-menu.
Regenerating model.
Command: _RBCS_bentplate
Select plate(s) :1 found
Select plate(s) : Choose method [by2points/byLine]<by2points>:L
Select line: Location of bending line[Center/Edge] <Center>
Specify internal radius or [Axial] <0.125000>:
Specify angle <90.000000>
Pick side to be wrapped :
*** Cut plane does not intersect selected part #1 ***
I changed the view to all views to WORLD, TOP, BOTTOM, LEFT RIGHT, FRONT & BACK  but the error is always the same :  *** Cut plane does not intersect selected part #1 ***
Thank you very Much
PEDRO E
Product Support
Jakub.Brozonowicz
Message 2 of 4 (929 Views)
Re: Bending A Plate
04-11-2012 01:49 AM in reply to: detailer_wsa
Could you pleae share the file with a plate to check?
Jakub Brożonowicz
detailer_wsa
Message 3 of 4 (917 Views)
Re: Bending A Plate
04-11-2012 08:56 AM in reply to: Jakub.Brozonowicz
Here is the file of the bent plate I cant bend. the white lines are the bending point
Valued Contributor
tedmail
Message 4 of 4 (824 Views)
Re: Bending A Plate
05-24-2012 08:28 AM in reply to: detailer_wsa
I assume it just doesn't work?  I get the same results as described and have not been able to bend the plate.
Actually, after finally playing around with it quite a bit, and knowing I tried these exact same steps before, I was able to get the bend done.  Things to take note of:
The Z coordinate should be perpendicular to the face of plate.
180 degree bend is actually not a bend at all, but keeping it flat.
The radious should be .1 and go up from there to get your desired bend.
But at least it gets the job done...
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
