Hi guys,
Somebody can tell me how I can set up my connections? I try connect the rafter to purlins, or columns with beams, and in almost of types say,that connections it doesn´t fit in this set. "Selected profiles does not meet criteria of this type of connection."
It's a kind of bug in my Autocad or just my unknowledge
See attached image...please
Is there any chance to get your file to check, please?
Hi Pedro,
Still nothing attached.
I'm wih the same problem, except that I created my profile (didn't find it in AISI, cold formed).
I am able to create the purlin, but I'm not able to create the connection purlin - rafter (same error as "beginner", selected profile does not meet criteria of this type of connection).
PLEASSSSEEEE HELLLPPPPP! It's been days that I try.
Made rafter H or T section
Make purlin - rafter connection
Change rafter section for your U
SOOO MANY THANKS!!!
Now I think there is only left to know how we can make the welding to show up (I was also trying to make weld appear, make it visible in the countour of the welding).
If you can help, I would appreciate.
Best regards,
Bruno Freitas
BULL'S EYE!!! This was most awesome!
Once again, thank you!!!! HOOOORRRRAAAAAYYYYYYY!
So, guys! It's me again!
I was wondering... when you look at a existing profile, it shows properties... When you create (region) a profile, I didn't manage to put properties.
Does it follow a pattern? Can we put the properties (like density of profile,for example)? How?!
I feel we are getting there!
Edit database 😛
Additional info ... or use search
