I am wondering if someone could please help me.
I am having problems generating connection welds on an "End Plate - Beam/Beam with Rib" connection using AutoCAD Structural Detailing 2015.
I have generated these connections on several of my Beam/Beam connections where it generated perfect, but for some reason when trying to add the connection on some of the beams that looks exactly the same as the previous ones generated (same length, rotation and profile), it does not want to generate the welds giving me a new assembly positions number for the beam.
I have done the connections manually and I also used the "copy connection" function but still I am getting the same problem.
Thank you
