For structural elements(members) created using "BEAM"/"COLUMN" in ASD-MODEL - we are not able to get "CONNECTIONS" such as shear plate/clip angle etc.,
Thanks for reply,
Please find the attachment :Frame.dwg ,where we are not able to achieve any coulmn beam connections using "connections"macro
Hi !
Can't made any connection for plate compound assembly :S
Edit USER database and made profile, and u can use any connection macro !
User database -> c:\ProgramData\Autodesk\Structural\Common Data\2014\Data\Prof\Ruserpro.xml
Regards
Csillag
We have used "BEAM" element in ASD-Model to gererate columns and beams as shown in the previous attachment frame.dwg. These generated beams are made up of PLATES(automatic generation by ASD).This is exactly the way built-up beams/columns fabricated.
As suggested by you , if we generate beam using profile and use automatic positioning, bill of materials will have only one position mark(as a single beam) instead of three positoin marks(for three plated built-up beam). This is the reason for trying to get connections for "BEAM" element (plate compound assembly).
strlblr
