AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Beam/Column Connection
6 REPLIES 6
benniebadenhorst
1583 Views, 6 Replies
I want to create a beam to column connection. There is identical beams on both sides of the column web. I see that you can create a double sided clip angle connection, but I was looking to create a double sided end plate connection. Is this possible? Any guidance would be appreciated.
6 REPLIES 6
Please look at movie here.
It might be a solution but not by one connection and no connection ability is kept for such solution unfortunately.
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Jakub Brożonowicz
Global Product Support
There is a macro that can do this. It is called "2beams to column web" which does exactly what you wannt.
@Jakub: Why would someone do that when there is a macro fo that?
Regards.
Thank you. That is why I asked. I couldnt think that they would not have this macro. And all this time I was looking under the wrong group of connections.Smiley Happy
True.
My oversight.
Thanks.
Jakub Brożonowicz
Does the suggested macro work if the beams are not the same size?
lucis29
in reply to: benniebadenhorst
Yes.
”Boost
”Tips
