AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Automatic drawings
4 REPLIES 4
Scrambled
717 Views, 4 Replies
Automatic drawings
I have a question about the automatic drawings.
I draw a lot of iron industrial and residential railings.  Is there a way that the automatic drawings can place a mark on the center of the flatbar or channel where we need to punch the holes for the pickets.
Right now when I do the automatic drawings that use 1/2 x 1 bar channel, for the horizontal member of the handrail and 1/2 x 1/2 square bar for the pickets.  The automatic drawings show me the correct length to cut both the 1 x 1/2 bar channel, and the 1/2 x 1/2 square bar with the correct piece count, but it does not show me the location to punch the square holes so that the bar channel and sq bar can be assembled and welded together.
Is there a way to include the holes, or am I going to have to keep adding them manually ?
Steve
4 REPLIES 4
jenyzosin
in reply to: Scrambled
hy
check settings
here is a sample
There's a fine line between genius and insanity. I have erased this line - O.L.
zcsillag
in reply to: jenyzosin
And ???
Regards
Csillag Zoltán
Scrambled
jenyzosin
I tried to follow your directions, but I did not have any luck.
Do you have any more suggestions?
When I change the style, do I need to create a new drawing, or just update the existing drawings?
Thanks for the help
Steve
jenyzosin
Just update your drawing
”Boost
”Tips
