AutoCAD Structural Detailing 2014 is built on AutoCAD, so we can run the same plugins which run on AutoCAD.
After running business logic inside the plugin, I would like to automatically create reinforcements.
I would like to run DEF_BAR_BV command with parameters such that we can create reinforcements without using Dialog Box.
I would like to select a line from drawing and automatically convert it to reinforcement. User currently has to go through a long procedure and fill up values inside dialog boxes. Although the line has a associated text which are the inputs to the dialog box when we run DEF_BAR_BV.
Or
Is there a way that I can add attributes to Lines in such a way that when the drawing file is opened is ASD, It recognizes them as reinforcements.
Thanks.
