Having a problem with assembly drawing
- An assembly AB 8 whereby automatic drawing is done (Expected to have the AB8 And the B8 details ) but only having AB8 as drawing
- the detail of the beam B8 is not attached to the assembly drawing of AB8
The why of this ?????????
refer to annexed picture
Solved by Delvin.Ramassami. Go to Solution.
Is "Assembly and parts" mode chosen for views arrangement?
Yes Assembly and part have been selected .
Note that the assembly is a loose part one - does this change things ?
Ok good but is this the right way is there any other way ?
For my case :- a beam is site welded at both end an considered as an assembly loose part
it give me only the assembly part but not the detailed profile ..
But
when having clip angle it works as intended giving the assembly, the detail profile and plates
why not for loose assembly ?
Another Easy and relatively quick way is to add the details profile that is Add to current printout .
