AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
ASD2011-Reinforcement Module-BUGS-Please need hotfix
4 REPLIES 4
1707 Views, 4 Replies
ASD2011-Reinforcement Module:
1- Spliced bars shown in section (created by ASD2011) of reinforcement surface distribution is not aligned. (Please see attached JPG file Plan-section)
2- The measured concrete cover of the spliced bars shown in section is incorrect (not equal to the value which is defined in the cover field in Surface reinforcement-bars window).
3- Bars will be located outside the section when section moved. (Please see attached JPG file Plan-moved section)
This is very serious mistake.
Regards
4 REPLIES 4
There is no effect after applying Service Pack SP2. The problem still exist.
I'd just use a quick leader note, and note the correct positioning, so you don't have to use a bunch of modifying to get the look you wanted. Just a quick fix. This is another one of those things that is beta about this software. It could use a lot of changes.
In ASD2012, there is no effect after applying Service Pack SP2.
The problems still exist. !!!!!!!!!?????????Smiley Mad
After applying SP3 (with HF1 and HF2) on ASD2012
Finally, it is solved. Well done, many thanks to Autodesk development team of ASD.Smiley Happy
Best regards,
Abbakeer
”Boost
”Tips
