ASD2011-Reinforcement Module:
1- Spliced bars shown in section (created by ASD2011) of reinforcement surface distribution is not aligned. (Please see attached JPG file Plan-section)
2- The measured concrete cover of the spliced bars shown in section is incorrect (not equal to the value which is defined in the cover field in Surface reinforcement-bars window).
3- Bars will be located outside the section when section moved. (Please see attached JPG file Plan-moved section)
This is very serious mistake.
Regards
I'd just use a quick leader note, and note the correct positioning, so you don't have to use a bunch of modifying to get the look you wanted. Just a quick fix. This is another one of those things that is beta about this software. It could use a lot of changes.
After applying SP3 (with HF1 and HF2) on ASD2012
Finally, it is solved. Well done, many thanks to Autodesk development team of ASD.
Best regards,
Abbakeer
