AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
ASD2010 / REINFORCEMENT FATAL and INTERNAL ERRORS
4 REPLIES 4
abbakeer
1676 Views, 4 Replies
Please help to solve the following errors:
FATAL ERROR: Unhandled Access Violation Writing 0x48d589f3 Exception at a5a42a8h
FATAL ERROR: Unhandled Access Violation Reading 0x03b8 Exception at 25ad32edh
FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at 250f1b1ah
FATAL ERROR: Unhandled c0000417h Exception at 7858c955h
INTERNAL ERROR: !dbobji.cpp@7227: eNotOpenForWrite
FATAL ERROR: Unhandled Access Violation Reading 0xfffd Exception at 771248a4h
Thanks, Edited by: abbakeer on Jun 9, 2009 5:41 AM add another FATAL ERROR
4 REPLIES 4
gav9999
in reply to: abbakeer
I also had the same problem.
I got IT to reinstall the software.
Problem fixed.
mapage
Which software did you have them reinstall? The full Acad2010 program or something else?
Abbakeer, have you solved these problems yet?
I'm getting the FATAL ERROR: Unhandled c0000417h Exception at 7858c955h message and I'm kinda stuck.
abbakeer
Please see " To avoid ASD2010-reinforce.-surface reinforcement distribution-fatal errors
Posted: Oct 7, 2009 8:24 AM "
FOR U-BARS / CREATED BY
SURFACE REINFORCEMENT DISTRIBUTION-BARS OPTION
To avoid the fatal errors related to the modification of the ASD2010-REINFORCEMENT-(SURFACE REINFORCEMENT DISTRIBUTION-BARS), the Minimum bar length for surface distribution ( defined in Job preferences / Bars / Options ) should be > = [ (2 x Bar diameter which is shown in the required projection) + Bent diameter (according to the selected code) ].
This because the Minimum bar length for surface distribution does not mean the total length of the bar, but it means the projection length of the bar.
If the fatal errors still exist, chamfering the corner with an edge length > = [ (2 x Bar diameter which is shown in the required projection) + Bent diameter (according to the selected code) ] will prevent the errors to come.
Moreover, the fatal errors are very sensitive to illogical / unreasonable modifications in the following fields (fields of Reinforcement detailing tab in the Reinforcement: definition and detailing dialog box.) :
1- two edit fields allow determining a value of the distance between the extreme reinforcement and the zone border; there is a possibility to block the distance value for each zone – once the distance on one side is blocked, the distance value on the other side will be automatically adjusted to a specified number of bars and a spacing value; after blocking the distance on both sides, the spacing will be adjusted automatically to a given number of bars.
2-the button located between the edit fields enables centering the distribution.
Also, increasing the bar diameter or the cover values without taking care about the above notes, will create the fatal errors.
I hope that Autodesk to check / review this part of the program, and issue new hotfix or service pack.
kari_sinkko
That's quite an interesting error solution, the only problem i have is that I use Autocad Architectural 2010 (ACA) and we get errors like this all the time (3 to 15 times easy per day).
K
”Boost
”Tips
