Solved by StefanoPasquini6790. Go to Solution.
Good day,
my best advice is that you perform menuload on command bar. Reload RBCS (Steel, Reinforcement and Formwork) and ASD mnu.
I hope that helps
Good morning (CIAO)
try to create a new file from template RBCS039, everything will be all right!
Greetings
Why, when you change the workspace and returns to ASD Steel, tab switches to Layout Edition, even when it was in Model when it left the Wokspace ASD? That is,
You can keep tab of the Model fixed so that when you return to the Workspace ASD, it does not switch to the Edition Layout tab automatically?
