AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
ASD with Civil3D?
6 REPLIES 6
701 Views, 6 Replies
ASD with Civil3D?
I have Civil3D installed on my machine, and I just installed my Revit Structure Suite, with AutoCAD Structural Detailing. However, when I try to launch it, it will load Civil3D and close without warning right after startup.
Are there any known issues with side-by-side installs of these 2 productr?
6 REPLIES 6
Any idea guys?
Now I managed to start ASD using ACAD instead of C3D, but once the Structural Detailing Splash Screen opens, I get an unhandled exception (the same one twice) and ACAD shuts down right away.
I'd like to test it out, but if I can't make it work it's going to be difficult... See attached image.
Please try the following:
1. Start ACAD 2009 (ACAD alone! Not ASD!) – does it start OK?
2. Close ACAD 2009
3. Start ASD 2009 – does it start OK?
Hope that helps
Darek Message was edited by: Dariusz Kwolek
Hi Darek
Yes ACAD does start correctly, no issues there.
When I start ASD after starting ACAD, I get the dialog box asking me to chose between steel, formwork and reinforcement. Say I click on steel...
ACAD does start and loads RBCS-044.dwt. But I get a prompt asking me i I want to show or not show proxy graphics. Whatever I chose, ASD will continue loading and eventually give me an unhandled exception error message and close. I've attached the screen cap of the error message.
Strange…
I would like ask you to do as follow:
1. Run ASD
2. Run Steel module
3. Before you get proxy graphic dialog box try to enlarge the command line zone and make a screenshot starting from the beginning of command line or copy and paste the content of command line and attach as a text file.
Darek
Thanks Dariusz but I'll be switching computers very soon, so I decided not to spend too much time on this...
I'll let you know If I get the same problem on my new machine...
”Boost
”Tips
