AutoCAD Structural Detailing General DIscussion
Valued Contributor
17 Kudos
Post 1 of 3
ASD reinforcement 2013 - insert drawing from ROBOT 2013 not working
914 Views, 2 Replies
08-14-2012 09:33 PM
I have RSA pro 2013 Sp2 and ASD 2013.
I have robot file with rc column reinforcement drawing.
When I try to "insert drawing from Robot" it gives me te following error: Error load type library / DLL.
I have tried this on two different PCs.
Any suggestions?
____________________________________________
If you find my post useful give me Kudos. Thank you!
If my post solved your problem, accept it as a solution.
The situation is:
Both Robot and ASD 2012 and 2013 are installed.
Robot 2012 is then uninstalled.
Reported problem:
It is no longer possible to open RC drawings created in Robot 2013 in ASD 2013.
Solution:
It is necessary to manually delete the following registry key:
[HKEY_CLASSES_ROOT\TypeLib\{1517EFF1-9EC2-11D4-B22C-0080C86BDF8D}\1.0\0\win64]
Mind that that key has to remain:
[HKEY_CLASSES_ROOT\TypeLib\{1517EFF1-9EC2-11D4-B22C-0080C86BDF8D}\1.0\0\win32]
Reason:
Uninstalling of Robot 2012 leaves the excessive registry key which should be reased during this process
Priit:
Please confirm that the above solution solved this issue. Thank you.
Product Support
760 Kudos
Post 2 of 3
Re: ASD reinforcement - insert drawing from ROBOT not working
08-22-2012 07:04 AM in reply to: Priitl220
The situation is:
Reported problem:
Solution:
Reason:
Priit:
Artur Kosakowski
Valued Contributor
17 Kudos
Post 3 of 3
08-24-2012 12:34 AM in reply to: Artur.Kosakowski
I have more than one PC, so I made a reg file to make it easier. Enjoy.
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
