In Autocad I create as many layout tabs as I want. In ASD the max is 5, it does not show more than that even they show in the object inspector. I need more than 5 layout tabs for using the "publish" command.
Solved by Redli1. Go to Solution.
Got it. They just don't start appearing until you click on the layout out in the sheet set manager. But is there another way for them to appear?
