Hi dear,
How to show more than 5 layouts tab without using object inspector.
we have to use this option for exporting layout to pdf format.
Thanks & Regards,
Vijay Waghare
Solved by Pawel.Pulak. Go to Solution.
Solved by StefanoPasquini6790. Go to Solution.
Hi Vijay,
I have the same question for adsk, I like to know how can we make a pdf or dwf file with all the automatic printout selected or created.
Greetings.
It can be done setting the higher value of SETPBUF variable. By default it is assumed as 5.
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Find attached file. There are automatically export pdf for all layouts.
Vijay Waghare
