AutoCAD Structural Detailing General DIscussion
Valued Mentor
Rich.O.3d
Message 1 of 4 (592 Views)
ASD equivalent of Prosteel unlock constraints to stretch
592 Views, 3 Replies
05-22-2012 10:24 PM
In prosteel, you unlock constraints, then you can use stretch to adjust frames, then you relock constraints.
Is there a similar method in ASD
currently when stretching the end of beams, they default to move with amount of the stretch.
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
StevieWonder
Message 2 of 4 (498 Views)
Re: ASD equivalent of Prosteel unlock constraints to stretch
10-17-2012 12:10 AM in reply to: Rich.O.3d
Hi I have the same problem, I'm actually disappointed that nobody posted a solution as this is a common operation as designs change constantly and If you have to make rapid changes... Re-assigning all end treatments, grating sizes, hand railing etc. Will be sooooo mundane and time consuming!
PLEASE SOMEONE HELP
-=StevieWonder=-
"Trust me, I'm a draftsman"
Distinguished Contributor
markhubrich
Message 3 of 4 (483 Views)
10-17-2012 10:07 AM in reply to: StevieWonder
this button right here...
see attached
Is this what your looking to do?
StevieWonder
Message 4 of 4 (469 Views)
10-17-2012 11:04 PM in reply to: Rich.O.3d
Hi thanks for the reply!
Actually no it does not stretch/extend members it also moves them? What I want is for instance a row of secondary beams joining it's main beams e.g. 1000 centers apart and now the the distance changed to 1500 centers apart.
Now, if I move the main beams to 1500 obviously the secondary beams stay put. Instead of having to go thru the long operation of extending each and every beam and re-attaching it's gussets and cleats etc. I thought I could use the normal stretch tool under  home_modify_stretch and select all member incl. the main beam? This is not stretching the members it only moves them.
-=StevieWonder=-
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
