Hi everyone,
is there someone that use ASD with a workstation with a Solid State Memory? Do you think that this can help the manage of the big dimension models?
I'd like to recive your opinion about it, because I want to try this solution...
Greetings at all.
Solved by CristianLANCULESCU1367. Go to Solution.
No Stefano,
It doesn't matter if you have an SSD. Autocad is simple not made for 3D models.
I have 16GB of RAM and SSD for 2 years (3 ASD versions) and there is no difference.
Thanks a lot Cristian,
Now I can save a lot of Euro to purchase Solid State Memory...Do you have intention to change ASD with another software? Are you an Autodesk Robot Structural Analysis user? Do you use Revit? Do you belive in Revit Structural progress?
Greetings
