AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
ASD 2015 Position BUG
40 REPLIES 40
Message 1 of 41
CameronEJF
3516 Views, 40 Replies
Every time I try to Auto position parts or Manually position parts the program freezes. This is rediculious. Please tell me someone else is having these issues?
40 REPLIES 40
Message 21 of 41
jenyzosin
in reply to: zcsillag
Prin 2006÷2008 era o placere sa lucrezi cu cei de la ROBOBAT. Raspunsuri rapide la probleme, update sau hotfix in max. 2 zile..., dar daca au pensionat echipa ROBOBAT ar trebui sa inchida "chioscul" si sa returneze banii clientilor nemultumiti.
There's a fine line between genius and insanity. I have erased this line - O.L.
Message 22 of 41
zcsillag
in reply to: jenyzosin
cine da inapoi 1700 Euro ... si asta e doar subscriptia 😄
Regards
Csillag Zoltán
Message 23 of 41
jenyzosin
Nu stiu.
A incercat cineva la OPC?Robot Happy
Message 24 of 41
zcsillag
OPC e pt personae fizice :S
Regards
Csillag Zoltán
Message 25 of 41
We don't understand your posts...only 1700 € is clear.
Greetings..
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
Message 26 of 41
1700Euro = subscription/year for nothing :S
Regards
Csillag Zoltán
Message 27 of 41
dgorsman
While some AutoDesk personnel come in from time to time, this is user-to-user support.  Problems reported here will usually not get logged by AutoDesk.  Direct product support isn't delivered through this forum either.  Constantly posting won't help get any fix get done faster.  Ever had your boss riding your backside to get something done, hovering over your shoulder every few minutes, wondering aloud what they pay you for?  Does that make your work go any faster?  Thats what you guys are doing here.  This isn't a simple "click a toggle box" type of fix, there isn't any skullduggery afoot.
Not only does this not help, the constant unhelpful posts don't make for a welcoming atmosphere for AutoDesk personnel to volunteer additional information or lend a hand.  If you wish for more participation by AutoDesk (like a better idea what fixes are being worked on) then a higher level of professionalism will work wonders.
Message 28 of 41
arnel01
in reply to: jivkomitev2
This does not solve the bug 100% but it help a little. Thank You.
Message 29 of 41
rajaspidey
in reply to: CameronEJF
Message 30 of 41
sbekkers
in reply to: rajaspidey
I had to open my file in 2014ASD to do the positioning, can I now open this file in 2015ASD and work with it without issues?
Message 31 of 41
Hi evryone,
Just installed the ACAD 2015 service pack 1 and the positioning bug is dead! I made only few tests, but something is changed!!!
I wish you the best...we are "patience" hero with adsk speed with ASD!!!!
PasProStudio
Message 32 of 41
KamikonLK
Message 33 of 41
sbekkers
in reply to: KamikonLK
thanks, I will give ti a try.
Message 34 of 41
tanks !! work great 🙂
Message 35 of 41
vanvan11
10x Jivko Mitev it works!!
you save my day
Jivko Mitev solve the problem!!
Благодаря много Живко 🙂
Message 36 of 41
vanvan11
благодаря за точния отговор
спестихте ми много време от ръчно номериране
вече нямам проблеми с номерацията от както прочетох поста ви
Още веднъж благодаря единствено пробвах с 01 за начално и също се получава въпроса е да не е 1
Хубав ден
Message 37 of 41
zcsillag
in reply to: vanvan11
English ?
Regards
Csillag Zoltán
Message 38 of 41
vanvan11
i think jivko mitev is right
so i told him 10x
and couse hi is bulgarian one i use bulgarian
is that cool?
Message 39 of 41
goodbuilders
Where do you put the fix?
Message 40 of 41
vladmircea75
in reply to: goodbuilders
Thank you for help.
Installation Instructions
To install ASD_2015_Positioning_Hotfix
You must have administrative privileges on your Microsoft® Windows® operating system to complete the installation process.
This installation requires you to replace the following file:
    • RBCTCore.dll
To replace this file
  1. Restart system
  2. Navigate to ASD installation folder; for example C:\Program Files\Autodesk\AutoCAD 2015
  3. Rename the affected original file:
    • In the product installation folder, right-click the RBCTCore.dll file and rename it to RBCTCore.bak
  4. Double click the file:
    • ASD_2015_Positioning_Hotfix_64bit.zip
  5. Extract RBCTCore.dll to ASD installation folder; for example C:\Program Files\Autodesk\AutoCAD 2015
”Boost
”Tips
