AutoCAD Structural Detailing General DIscussion
Product Support
Jakub.Brozonowicz
Message 1 of 2 (309 Views)
ASD_2014_Layouts_Hotfix is live
309 Views, 1 Replies
07-02-2013 12:19 AM
http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=21962610&siteID=123112&linkID=12952913
This hotfix will fix the issue with appearing new printing tabs, layouts and product instability related to their usage.
To install ASD_2014_Layouts_Hotfix
You must have administrative privileges on your Microsoft® Windows® operating system to complete the installation process.
This installation requires you to replace the following files:
      • RbctDrawingObj.dbx
      • RbctDrawingMngr.arx
To replace these files
    1. Restart system
    2. Navigate to ASD installation folder; for example C:\Program Files\Autodesk\AutoCAD 2014\ASD
    3. Rename the affected original file:
      • In the product installation folder, right-click the RbctDrawingMngr.arx file and rename it to RbctDrawingMngr.bak
    4. Navigate to AutoCAD 2014 installation folder; for example C:\Program Files\Autodesk\AutoCAD 2014
    5. Rename the affected original file:
      • In the product installation folder, right-click the RbctDrawingObj.dbx file and rename it to RbctDrawingObj.bak
    6. Double click the file:
      • ASD_2014_Layouts_Hotfix_32bit.zip or ASD_2014_Layouts_Hotfix_64bit.zip
    7. Extract RbctDrawingMngr.arx to ASD installation folder; for example C:\Program Files\Autodesk\AutoCAD 2014\ASD
    8. Extract RbctDrawingObj.dbx to AutoCAD 2014 installation folder; for example C:\Program Files\Autodesk\AutoCAD 2014
Jakub Brożonowicz
zcsillag
Message 2 of 2 (287 Views)
Re: ASD_2014_Layouts_Hotfix is live
07-02-2013 04:45 AM in reply to: Jakub.Brozonowicz
What are the beta testers doing? This things should not be present from one version to another. More then that, nothing has been done since de 2012 version.
Regards
Csillag Z.
Regards
Csillag Zoltán
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
