http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=21962610&siteID=123112&linkID=12952913
This hotfix will fix the issue with appearing new printing tabs, layouts and product instability related to their usage.
To install ASD_2014_Layouts_Hotfix
You must have administrative privileges on your Microsoft® Windows® operating system to complete the installation process.
This installation requires you to replace the following files:
- RbctDrawingObj.dbx
- RbctDrawingMngr.arx
To replace these files
- Restart system
- Navigate to ASD installation folder; for example C:\Program Files\Autodesk\AutoCAD 2014\ASD
- Rename the affected original file:
- In the product installation folder, right-click the RbctDrawingMngr.arx file and rename it to RbctDrawingMngr.bak
- Navigate to AutoCAD 2014 installation folder; for example C:\Program Files\Autodesk\AutoCAD 2014
- In the product installation folder, right-click the RbctDrawingObj.dbx file and rename it to RbctDrawingObj.bak
- Double click the file:
- ASD_2014_Layouts_Hotfix_32bit.zip or ASD_2014_Layouts_Hotfix_64bit.zip
- Extract RbctDrawingMngr.arx to ASD installation folder; for example C:\Program Files\Autodesk\AutoCAD 2014\ASD
- Extract RbctDrawingObj.dbx to AutoCAD 2014 installation folder; for example C:\Program Files\Autodesk\AutoCAD 2014
Jakub Brożonowicz
Global Product Support
