The hotfix appeared to work at first when opening a multi layout affected file.
Now every time I try to activate a drawings edition detail, it fatal error crashes me. Also while I sit here and type this, my ASD 2014 seems to be loading endlessly and it never loads.
I am completely dead in the water now.
Solved by markhubrich. Go to Solution.
Cannot open ASD2014. Performing reinstall.
I re-installed ASD and re-applied the hotfix. This is where I stand now...
http://www.screencast.com/t/CccoE5BsHmCs
The above is when I try to delete. Same results happen also when trying to activate the detail.
Cannot attach document either...
http://www.screencast.com/t/8by916iwgIWa
Mark, can you share the file with us? I've tried all the steps in one of my drawing, and it doesn't happen.
I wouldn't mind if you have a place to upload it. It's currently 35mb.
Here is latest attempt..
http://www.screencast.com/t/vEdfu7cX
I am going to try creating a new file to see if it's linked to my file or my ASD.
I just went through again step by step exactly what the hotfix says. I created a new file and added a column with beam connection.
It is not tied to my file. I get the same results with a brand new file.
My install of ASD is not in the standard location in Program Files. I have it installed on an SSD striped RAID of its own.
That wouldn't have anything to do with it?
I also noticed the RbctDrawingMngr.arx file exists in both the Autocad 2014 and the ASD folder.
Should this be replaced in both locations? I only replaced the one as called for in the hotfix directions
I followed the ASD description in hotfix and works Ok.
ASD is installed in his default directory, SSD, no RAID.
Windows 7 x64.
That did it. It sure didn't like having that file in the root autocad 2014 folder. I renamed it and it seems to be ok at the moment.
I'll try working a bit more..
I must have put the file in the incorrect location at first and the reinstall I did left it there anyhow.
Sorry guys I think I caused my own error here. 😐 I'm being poked at from every direction to wrap this up and my head is spinning to get it done.
Thanks for all your concern, I have my hopes that I can complete this journey.
I feel like complete tool. This particular Layout tab issue is resolved for me. Now back to the section cut crash issue. Seems that one is still happening.
