This hotfix will fix the issue with appearing new printing tabs, layouts and product instability related to their usage.
This hotfix is only for the Users who installed ASD 2013 SP2 .
http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=22013188&siteID=123112&linkID=12952913
Installation Instructions
You must have administrative privileges on your Microsoft® Windows® operating system to complete the installation process.
This installation requires you to replace the following files:
- RbctDrawingObj.dbx
- RbctDrawingMngr.arx
To replace these files
- Restart system
- Navigate to ASD installation folder; for example C:\Program Files\Autodesk\AutoCAD 2013\ASD
- Rename the affected original file:
- In the product installation folder, right-click the RbctDrawingMngr.arx file and rename it to RbctDrawingMngr.bak
- Navigate to AutoCAD 2013 installation folder; for example C:\Program Files\Autodesk\AutoCAD 2013
- In the product installation folder, right-click the RbctDrawingObj.dbx file and rename it to RbctDrawingObj.bak
- Double click the file:
- ASD_2013_Layouts_Hotfix_32bit.zip or ASD_2013_Layouts_Hotfix_64bit.zip
- Extract RbctDrawingMngr.arx to ASD installation folder; for example C:\Program Files\Autodesk\AutoCAD 2013\ASD
- Extract RbctDrawingObj.dbx to AutoCAD 2013 installation folder; for example C:\Program Files\Autodesk\AutoCAD 2013
Jakub Brożonowicz
Global Product Support
