Having an issue here where I am trying to set a default template for connections in ASD 2013 and I keep getting this runtime error every time I try to set the template to default and it just closes out of the connections dialog box. Any help would be great.
Solved by Jakub.Brozonowicz. Go to Solution.
Please try to remove (or rename) ConTmpl.xml file placed in C:\Users\loginname\AppData\Roaming\Autodesk\Structural\Common Data\2013 (W7)
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
