AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
ASD 2013 runtime error 440 Automation error
2 REPLIES 2
944 Views, 2 Replies
Having an issue here where I am trying to set a default template for connections in ASD 2013 and I keep getting this runtime error every time I try to set the template to default and it just closes out of the connections dialog box. Any help would be great.
2 REPLIES 2
Jakub.Brozonowicz
Please try to remove (or rename) ConTmpl.xml file placed in C:\Users\loginname\AppData\Roaming\Autodesk\Structural\Common Data\2013 (W7)
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Jakub Brożonowicz
Global Product Support
in reply to: Jakub.Brozonowicz
Wow thank you so much. That worked. I don't need to reinstall anymore.
”Boost
”Tips
