Is there any solution to fix a railing to any other than a steel member? I would like to use cored holes in concrete with a specified embedment depth.
Are you thinking about concrete member in Steel ASD module?
I was thinking I am detailing a ramp railing and I would like it if I can create the concrete slabs that make up the ramp using the "Formwork" interface of ASD. It would also be a plus if I could import and work with the concrete in the "Steel Project" module and choose the slab as a supporting member. In addition adding the different methods I might choose to attach to the slab. In my current situation I am coring the posts 6" deep and anchoring with anchoring cement.
The benefits would go beyond just railings. Many situations have me manually drawing in concrete supporting structures for structural erection details.
@ AutoDesk
"Are you thinking about concrete member in Steel ASD module?"
I like the Idea of concrete members in ASD, without having to switch over but material be separated on Object inspect.
any posibility of getting such functionality on next version?
Using the user defined section like on this recording?
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
