AutoCAD Structural Detailing General DIscussion
Active Member
0 Kudos
Post 1 of 5
ASD 2013 - Producing a Plan View (General Arrangment) Layout
640 Views, 4 Replies
09-25-2012 11:14 AM
What is the procedure for developing a Plan View, with text and dimensions and titles?
Valued Contributor
7 Kudos
Post 2 of 5
Re: ASD 2013 - Producing a Plan View (General Arrangment) Layout
09-25-2012 12:09 PM in reply to: csammons
That's like asking how to use a computer.  A bit too vague of a question.  You first need to create your model if you want automatic drawings to create a "plan view".  If you are asking about a general view, they have what is called a schematic, I beleive.  You can create a top view of any part, group or assembly, however.  Or you can draw out a plan in model space with lines and print that like the old days.
We could offer more help if I knew what stage you were at and where you wanted to end up.
Active Member
0 Kudos
Post 3 of 5
09-25-2012 01:09 PM in reply to: tedmail
My aplogies if I was not making myself clear. I have generated a model, a steel pipe support bridge. I am able to generate shop drawings. I want to create an overall Plan View, with the visible beams and columns labeled. As of now, I can create the plan view using mviews, but I have to place the labels and dimensions in paper space. I wish to use the templates to create a Plan View general arrangement layout.
Valued Contributor
7 Kudos
Post 4 of 5
09-25-2012 01:14 PM in reply to: csammons
You are after the schematic type drawing template.
Valued Contributor
5 Kudos
Post 5 of 5
09-25-2012 02:22 PM in reply to: csammons
just creating a group, then insert it as block into your layout.
See below the attached.
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
